Alt 20.06.2011, 12:21:20   #8
Cherry
Benutzerbild von Cherry
Liest du auch, was du postest? Da geht es nicht um die Webcam, sondern um Privacy-Probleme (nachverfolgbarkeit deines Rechners) durch Flash-Cookies.
Zitat von ESET
Use of the global privacy settings panel does nothing at all to stop sleazy online ad agencies and other scum from using flash to track you individually. This is actually not a global privacy setting at all, it is simply a control for your webcam and microphone. By default if a Flash application wants to use your camera or microphone it has to ask, but you can choose to always deny the request. The proper setting for this panel is whatever you want. This isn’t about privacy at all, this is simply do you want to the choice to share your webcam or do you want to make sure it is never used and you are not asked. Calling this the “Global Privacy Settings panel” is an example of the devious and deceptive nature of Adobe.
Ja, man kann Flash (und Adobe) scheiße finden, man kann es auch leicht als "Spyware" klassifizieren... das alles hat aber nix damit zu tun, daß es heimlich per Webcam Aufnahmen machen würde.
Cherry
