Alt 01.03.2007, 22:16:13   #1
jerzy
Standard problem - my engine sound
Hello, i have problem with my gs500. listen it on my page http://jerzy.wz.cz/motor.wav
Can you tell me where is my problem?
Please, dont speak german, i dont understand and my english is also VERY easy, sorry.
Alt 01.03.2007, 22:47:03   #2
schwer zu sagen bei der Aufnahme...für Pleuellager wär`s mir zu viel rasseln...vielleicht die Steuerkette?
Alt 01.03.2007, 22:58:09   #3
jerzy
No idea - i understand, thanks for now
Alt 01.03.2007, 23:02:39   #4
be patient
Alt 01.03.2007, 23:07:36   #5
jerzy
Saugwurmmensch > I will
Steuerkette, i dont know translation in english, bud i know what you speak about. People on czech bikes forum says it too.
is steuerkette endless chain or not? (i think when it leaves factory in GS)
Alt 01.03.2007, 23:12:22   #6
Zitat von Goose
Er möchte doch mal ne bessere Aufnahme machen, und vieleicht auch mal was länger und auch mal Gas geben dabei.
So übersetzt mal bitte einer.
i'm goose. I don't speak a word english. I want better sound
gut so ?
Alt 01.03.2007, 23:18:12   #7
jerzy
I cant give you better sound, only from my nokia 6230, sorry. but what is important in that sound is clacking in cca 1 second interval.
steuerkette = timing chain or cam chain
Alt 01.03.2007, 23:24:12   #8
jerzy
Zitat von Goose
stearing chain? for the valves
also
Alt 01.03.2007, 23:24:47   #9
another, longer soundfile where You rev up the engine would be a further help.
Alt 01.03.2007, 23:28:57   #10
jerzy
When i rev up engine, everything is ok. i can hear it only on neutral(idle running) or when rev down(turn off gas).
Alt 01.03.2007, 23:30:02   #11
gruenkai
I'd say the camshaft axial clearance is too wide.
Lay the bike from left to right. Does the sound change?
Alt 01.03.2007, 23:34:39   #12
jerzy
thx for answer, will try tommorow.
I forgot something, when i start engine, sound is clear, my problem appears only with warm engine.
Alt 01.03.2007, 23:39:14   #13
whombom
you could check, or just replace (it's not that expensive) the cam chain tensioner... a friend of mine blew his out once, and it had about the same symptoms as you are having (rattling in low rpm, running fine at higher rpm)
Alt 02.03.2007, 00:19:36   #14
gruenkai
Another indication for the camshaft axial clearence.
If the clacking disappears when laying the bike on the left or on the right side (with the feet on the ground ), then it's perfectly normal. Well, not perfect, but normal. Just get used to the sound, it won't do any harm to your bike.
Alt 02.03.2007, 10:14:19   #15
Eleven7
Benutzerbild von Eleven7
Yes, as said before:
Sounds occuring only in warm engine conditions is - let´s not say good, but - better sign. Quit possible due to wrong adjustments made.
A rather loud, metall sound repeating up to 3 times per second is axial clearance of the camshafts. They bounce from sides to sides making that noise.
If you hear high frequent "click" sounds, the cam chain (stearing chain) which drives the camshaft might not be configured the right way. And the valve open/close not exactly the way they are supposed to do.
There´s the possibility, the chain longened due to wear, or the camchain tensioner might have a scratch (change!).
You might want to go to a dealer and get that check, since broken camchain tensioners can lead to fatal engine failure.
...Or the clearance for valve adjustment are WAY out of tolerance, this is eligible for home-checking. Check the video below!
Check out these topics:
http://www.gs-500.de/viewtopic.php?t=5999
Strange Sounds Explanation, in German language, though.
http://video.google.de/videoplay?doc...lve+adjustment
Valve adjustment video, in english
Translator: http://www.tranexp.com:2000/Translat...esk-german.htm
EDIT: Some members of quite bigger experience than me wish to have a soundfile, that covers the whole bandwidth of rpm, including reving up the engine and so on.
Alt 02.03.2007, 14:33:09   #16
jerzy
Hi, im here again. As you said i did before few minutes. I layed bike on the left and on the right side and sound was clear(after 5km)! Im not sure if i good understand you. You say everything is ok? Not perfect but ok?
I also checked valve clearance - ok
cam chain - ok
Can i be satisfied biker
Alt 02.03.2007, 14:50:22   #17
PEOPLES
yes, thats what he mean
as in the other tread described: it's possible to get some spacer-plates from suzuki to minimize the gap/play at the camshaft.
Alt 02.03.2007, 14:57:41   #18
jerzy
Im so HAPPY boys! http://www.nactileti.net/grafika/3ds...smajlik199.gif
I'd like thank everybody who helped me, especially gruenkai for good idea and Eleven7 for good video link! Thank you boys!
Zu -> "Engine covers and front fender" blub1254 Verkleidungen, Anbauteile und Zubehör 14 17.02.2008 17:09:37
engine covers and front fender hein vie the Verkleidungen, Anbauteile und Zubehör 10 27.01.2008 13:21:48
under engine auspuffanlage! chrimsor Auspuff 3 15.09.2006 18:04:42
Sound..... Allgemeines 51 19.08.2006 15:04:17
Sound Auspuff 7 27.10.2002 15:39:10
Alle Zeitangaben in WEZ +1. Es ist jetzt 12:55:39 Uhr.
