Alt 17.10.2012, 01:19:52   #1
blade8699
Standard Problem with main brake cylinder
First of all, sorry, but I know only English, and I need help
I have a problem with front brake cylinder. Plastic is broken, so oil is leaking.
Has anyone the plastic or can recommend what to do?
Thank you!
http://imageshack.us/a/img845/5935/img0098sv.jpg
http://imageshack.us/a/img254/8076/img0100tv.jpg
http://imageshack.us/a/img507/1726/img0101z.jpg
blade8699 ist offline   Mit Zitat antworten
Alt 17.10.2012, 06:06:15   #2
In recent times some other user have also had this problem.
The sight glass can not be replaced easily. Ask at your local dealer. If no solution, you need a new (or used) master cilinder.
You can also search the forum for "Schauglas" or "Bremsflüssigkeitsbehälter".
Search for "Schauglas" ist´s easier.
http://forum.gs-500.de/search.php?searchid=678399
Alt 17.10.2012, 08:18:06   #3
I've seen your GS is from 2005, may be you can ask your local dealer to change or fix the master cylinder using warranty. Seven years are just a very short life time for a master cylinder.
Alt 17.10.2012, 14:15:54   #4
blade8699
Thank you
Do you know any secure webshop to buy this? Or does it fit from any other model?
Alt 17.10.2012, 15:54:41   #5
You can looking for " Bremspumpe vorne " at "Biete" ( offers ) at marketplace (Marktplatz)
or try your own search ad at "Suche"
"Suche Bremspumpe / Flüssigkeitbehälter vorn "
Alt 17.10.2012, 16:01:24   #6
irgendwer92
The piece you look for hasn't got a part number, as you can see here: Alpha-Sports
So i don't think anybody can tell you which bikes have got the same plastic window.
It will also be difficult to get it without the whole brake-pump.
Alt 17.10.2012, 16:02:28   #7
irgendwer92
Rocky, i think it will be cheaper for him to buy it in croatian ebay.
Alt 17.10.2012, 16:06:45   #8
blade8699
Well, problem is that there is no Suzuki official dealer in Croatia, and also, this parts are rare on aou market of used parts.
Alt 17.10.2012, 16:14:32   #9
Generally, one can grow any brake pump (master cylinder) to the correct bore / stroke ratio and the corresponding connectors. However, it is much easier if you used the same series a fitting part. In my opinion, the GS 500 F would also have all of the Master Cylinder GS500E (GM51A / B) match.
You can even compare them out:
same part numbers = same parts.
A used brake master cylinder you can get on the Internet, for example ebay. or you try used parts dealers.
There is also the possibility here in the forum in the marketplace looking for the "Offer Share". Maybe you can find here the part.
http://forum.gs-500.de/forumdisplay.php?f=107
for example
http://forum.gs-500.de/showthread.php?t=31278 (Tokico Bremsanlage vorn, komplett)
front brake system completely
Alt 17.10.2012, 16:17:57   #10
Die der GM 51 A passen nicht! anderer Winkel wegen dem Superbikelenker....
Alt 17.10.2012, 16:50:46   #11
Translation:
The brake pump of the GM 51 A does not fit! Another angle of the Superbike handlebar ...
Alt 17.10.2012, 17:30:05   #12
irgendwer92
But he does only need to replace the window, not the entire brake pump.
Alt 17.10.2012, 17:41:03   #13
du kriegst es nicht einzeln!!!!!! Es gibt nicht eine Teilezeichnung wo es das Teil einzeln gibt.
Alt 17.10.2012, 18:07:14   #14
irgendwer92
Das hab ich dich vorhin auch geschrieben. Ich wollte dir nur sagen dass er einfach irgendeinen GS-Bremszylinder kaufen kann und das Glas austauschen kann.
Alt 17.10.2012, 18:19:42   #15
Na dann nimmt man doch gleich den ganzen Zylinder, der ist dann wenigstens dicht. Das Schauglas ist wohl nicht zum tauschen gedacht, sonst gäbe es das ja als Ersatzteil.
Alt 18.10.2012, 11:46:09   #16
there is no ebay in croatia ; as far as I know you will be redirected to ebay.de
@duje
what about this
http://forum.gs-500.de/showthread.php?t=30229
Bremspumpe mit Behälter (Ecke ist stark abgeschliffen, hält aber wohl noch dicht) 4€
- Brake pump with tank (corner is heavily abraded, but probably still holds tight) 4 €
Geändert von Rocky (18.10.2012 um 11:56:23 Uhr)
Alt 18.10.2012, 14:35:02   #17
blade8699
@duje
what about this
I will send PM. Thank you!
JET MAIN and JET PILOT AIR jerzy Vergaser - Kraftstoff - Drosseln - Tuning 7 11.10.2007 19:26:19
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:56:24 Uhr.
